RCU Forums - View Single Post - Help with throttle servo setup
Old 05-27-2008 | 11:31 AM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: Help with throttle servo setup
In the system menu of the DX7 there's a function called THROTTLE RECOVERY
Set it to ACT or active for the model you're working on.
Then follow the excellent post by Ram3500
Now, when you land you hold the trim down until the engine shuts down. When you let go of the trim give it 1 push upwards. That will set your throttle trim back to its original position so you get the same idle setting every time w/o twiddling with the trim to get a good idle.
