RCU Forums - View Single Post - control horn links relationship to hinge?
Old 05-08-2003 | 01:31 AM
Stick Jammer
Default control horn links relationship to hinge?
If the pivot point of the control horn is not on the hinge line you will get differential, meaning you will get a different amount of surface deflection in one direction than the other with an equal amount of servo rotation each way. If it's only slightly off, not a big deal as you can set the surface throw each way with ATV on a computer radio.
