RCU Forums - View Single Post - Makeshift Runway
Old 05-27-2008 | 01:16 PM
bingo field's Avatar
bingo field
Default RE: Makeshift Runway
The field I started used to be a pasture. I had to drag a steel beam behind my 4 wheel drive truck just to knock down the overgrowth. After it rains, you can use a roller and it helps smooth out the bumps. All my 40 and 60 size planes use 3" or larger wheels, and I use wheelpants on several planes without a problem. I cut the grass to 2 1/2" now and the only thing that kills me is the @$@#$#$ dandelions that you could cut twice a day, and they pop up in just a couple of hours. Look at the pictures http://www.rcuniverse.com/gallery/ga...m?clubgal=3698 and you can see what the weeds and brush I started with looked like.
