screwed up landing gear blocks
I just wanted to update all of you on the epoxy situation. I got a heat gun and softened up the epoxy. I also "cut" the landing gear rail in half by drilling holes all the way down it. Then, I just broke the rail in two and removed the rail when the epoxy was soft. It worked so well I not only got the blocks out, but the rail too. Thanks.
