RE: Ackerman Plate - which hole?
You should print out some set up sheets. I mark up a set up sheet for each different track I run on. That way I can set my buggy up the day before I race and make any fine adjustments day of the race. Your ackerman plate is only one of many adjustments you should make from track to track.
