ORIGINAL: a65l
Not to interfere with all the good advice going on here vis-a-vis the repair and all, but the Avistar's horizontal stab and vert are bolted in place.... unless you glued them, you can get replacement pieces and bolt them back into place....
A
Well, maybe. The ARF manual calls for epoxying the stabilizers in place and the RTF manual stipulates a bolt-on assembly. Can't tell from the pics which he has but I can detect a bead of something along the stab/fuselage joint I believe.
