RCU Forums - View Single Post - Trainer climbs like a Hot Air Ballon!
Old 05-27-2008 | 08:35 PM
BMatthews's Avatar
BMatthews
Default RE: Trainer climbs like a Hot Air Ballon!
ORIGINAL: DaveyWA
ORIGINAL: dignlivn
propbuster
I had the same experience yesterday with my Instructor. He said
"throttle contols Altitude" .
Bob
Some instructor you've got there.
Unless your model is 2 channels, throttle + rudder or something similar, then no, throttle does not control altitude, if it does, the wing incidence is incorrect as stated above
I hate to bust in but dignlivn's instructor is right. Other than on an aerobatic model throttle is supposed to control climb angle and elevator controls speed. This is the way it works in full sized aviation and with our trainers it's the same.... or rather it can be the same unless we trim this tendency out of the model using rearward CG locations, smaller decalage angles and downthrust. So really the instructor and you are both right but only from widely different perspectives.
