Hi,
I'm considering buying the following separate Balancer and Charger for LiPo's for charging 2100mah 3 cell 11.1v packs:
Balancer:
http://www.electrifly.com/chargers/gpmm3160.html
Charger:
http://www.dynamiterc.com/Products/D...ProdID=DYN4058
As far as I can tell, they are compatible.
Balancer manual suggests certain models of chargers, but it also says relating to compatibility, use with "
LiPo chargers and dischargers ONLY (operation based on nominal cell voltage of 3.7V per cell)".
Charger manual does not say anything good or bad about using a Balancer with it. Connections look like they will match up.
I have no experience with LiPo's... is there any possibility or reason that these two devices might not be compatible? Anything particular to look for in how each operates?
