RE: Trainer climbs like a Hot Air Ballon!
If your wing is attached with rubber bands then use more rubber bands. I have witnessed the LE of trainer wings raise up as speed increases or heading into the wind when not using enough rubber bands. It will cause your plane to climb drastically. No amount of elevator trim or down thrust will overcome this.
David
