RCU Forums - View Single Post - Fixing Avistar Horizontal Stab
Old 05-28-2008 | 09:19 AM
Nathan King's Avatar
Nathan King
Default RE: Fixing Avistar Horizontal Stab
ORIGINAL: bruce88123
If you use a doubler, place it on the front/rear surfaces and NOT on the top/bottom.
Doublers can be useful in the right situation, but I try not to use them as they add quite a bit of weight. You can either do as Ken suggested or cut out the damaged spots at a sharp angle and replace. Using a heavily angled cut will eliminate the need for a doubler since there is more surface area to glue to. Yes, it's strong. I did this with my Joker (old pattern aircraft) wing and can still do snaps on downlines, outside loops, figure 'M''s, etc without it breaking. Do yourself a favor and use wood glue.
