RE: Homelite 25 cc
Good find, too bad it was burned up. I just wish all these engines had Walbro carbs on them instead of the newer Zama lean burn carbs. With all the stuff laying around, I still have a shortage of good carbs. I am going to modify and run the Zama on this Homelite and see if it will work out. It seems to run lean at full throttle on the bench. If I adjust it to run ok full throttle, then it doesn't transition well. Idle mix is non-adjustable. I guess I really don't plan on running it full throttle anyway.
