RE: Zenoah G26 questions.
Yeah...although 2.4 may be less affected by RF noise, if at all, I've never liked the thought of blinding yourself to improper setup or failing parts, due to another component keeping you from noticing. Many folks still use older FM or PCM receivers to initially setup their plane and range check, engine running, to test for RF, and then move to their PCM or 2.4ghz receivers.
