Hi all! This poll is aimed primarly at Futaba owners, but also at non-Futaba owners who may not be aware that a lot of non-brand-specific information is available, and to those considering a futaba purchase.
So....here's the question(s)...
did you know that the futaba FAQ listed above has detailed programming instructions for things ilke setting up the Hanger 9 UltraStik on the 8U, 9C and 9Z with steps that are accurate and work?
(labelled as a 7-servo aerobat)
did you know the FAQ includes links to download nearly every Futaba manual ever produced?
did you know the FAQ includes answers to questions such as which modules are interchangable, how to legally change the frequency BAND (ie ground to air or back), what Futaba radios are and are NOT legal under the 1991 narrow band standard, etc?
do you find the FAQs useful? easy to navigate? can you find what you're looking for?
tell us if you use them or not? if so, what is most helpful? if not, and you knew the data was there, why not? (obviously some questions you want an non-manufacturers opinion, but for the type of data available, why would you use it or not use it?)
OK...i'm done tossing questions! Just trying to get an idea of how to make the site and info available better and more likely to be used!!
Sincerely,
Mrs. AnnMarie Cross
Senior Manager, Proprietary Service and Support
Great Planes Model Distributors
[email protected]
www.greatplanes.com
www.bestrc.com
