RCU Forums - View Single Post - Elevator pushrod binding
Old 05-08-2003 | 01:05 PM
vinnie
Default Elevator pushrod binding
Tempus, a small amount of binding is inherent in the type of pushrod you're using. If you feel it's excessive, check the radius of of any curves, look for irregularities on the inner rod and make sure the links from exit to control horn and servo are straight and not causing side loads. Talcum powder is a good lube if all else is normal.
