RCU Forums - View Single Post - Mounting PC Boards
Old 05-29-2008 | 08:43 PM
jshander
Default RE: Mounting PC Boards
I once tried using sticky tape on the solder side of the RAM boards and the sound wouldn't work right until I removed all the adhesive between all the metal contacts.
Since then I put the RAM board in large diameter heat shrink tubing and warm it enough to shrink wrap it.
I then put two sided stick tape on flat side of shrink wrap to mount it.
Jim Shander
