Dual ailerons
I am building an ARF. My old kit (trainer) had one servo that worked both ailerons. The new plane has two aileron servos. The manual says to use a Y harness if you are using a 5 channel radio, and not to use a Y harness if you are using a 6 channel or above. I have a 7 channel system Futaba 7C 2.4GHz with S3152 digital servos. The plane uses 5 servos. Since this is new to me could any of you give me any info on this? Should I set the second aileron on one of the unused channels? Is it better to do then then go buy a Y harness? I can handle setting it up with the radio, I will just need to read a lot..lol
Any tips or suggestions are appreciated!
