RCU Forums - View Single Post - Zenoah G26 trouble
Old 05-30-2008 | 11:33 AM
karolh
Default RE: Zenoah G26 trouble
Sometimes new engines take a bit of doing to get them to start pumping gas. If the engine is mounted upright on a test stand remove the plug and prime through the plug hole, or hand prime through the carb and have a go at starting, or better still if available use an electric starter and that should get you going. Also just check that both carb needles are at least 1.5 turns open just to get the engine going.
Karol
