RCU Forums - View Single Post - Dual ailerons
Old 05-30-2008 | 02:11 PM
PipeMajor
Default RE: Dual ailerons
I guess I don't understand. You have a modern 7 channel computer radio and dual aileron servos? Why bother with a Y harness? You should be able to select a flaperon wing configuration and get your ailerons to function using 2 channels plus get flaps. You should be able to get aileron differential as well (up/down ailerons move at different rates) which should help the adverse yaw issue.
