RE: AR6200
6200 problem solved!! After a fine tooth combing, and I mean fine!! A loose terminal end was found in the battery plug at the RX. It was not loose enough to come out when pluged in but apparently not seated such that the vibrations of flight would cause intermittent contact triggering the receivers to show a low voltage fault. This was a new switch assb., the ultimate needle in the haystack! Thanks to all who responded!
