I did a LT40 into a tail dragger this past fall.
Used a Dubro tail wheel bracket with a new wire going up into the rudder
Used plywood reinforcement as mentioned previously.
Has Aluminum gear from a H9 Super Stick 60 retained with nylon bolts tapped directly into the 1/4" plywood doubler I added inside behind F-2.
I converted the wing to bolt on with dowels in the front and nylon bolts in the rear.
