Problems?
Hi Spais,
I'm not sure what your ground wire issue is. No switch will have a ground wire for an electronic ignition. The switch should be used to interrupt battery power to the ignition and that's it. Can you send exactly what your manual says. Typically you do have to ground the ignition, but not through the switch.
As far as the loose pin, it's one of two things: one, you have a bad switch, and two(which is what I think it is, since I did it too), you aren't pushing the pin in far enough. It takes significant pressure to seat the pin. It is a very tight press fit.
**Oops, looks like Andy beat me by a couple of minutes. At least we seem to agree.
