RE: Control throw setup for Edge 540
Considering this is your first “high performance” plane I would suggest NOT setting it up with dual rates. IMHO you would be much better off just mechanically setting the throws for mild performance and maybe use some expo to take the sensitivity out around neutral stick.
You’re absolutely right about the limited resolution at 25%. Personally I would never use a rate that low for that very reason.
