RE: Menzs 27x10 SPLIT while in flight......
Good idea. Here's another item that I'm sure you've already considered. With the multi bolt hubs compression and clamping force really may not be that much of a problem. The single bolt hubs have more of a clamping force problem if they don't have an additional anti rotation pin in the hub.
I've been thinking that the dis-similar metals between the prop hubs and the prop bolts may be what's causing things to loosen up. I don't believe that a correctly torqued prop bolt is compressing the wood more as it's used, but the difference between steel and aluminum may be playing a big part. Perhaps stainless steel screws may be better suited to the task with aluminum hubs.
I didn't know you made bows, Pe. Now that's craftsmanship!!
