RE: Futaba 6014 receiver heat issue
Dick,
Julez notes that that component is having the temperature range in question which means that the outside of the receiver needs to be lower for that component to not go out of spec as the the component, and other components too, will generate heat inside the receiver. Not everybody are electronics or heat engineers so stating this fact is good I think.
