ORIGINAL: Swift427
Some would go so far as to say that the C discharge rating is just an arbitrary number. In other words it gives some indication of a batteries ability to discharge more amperage without going over 150 F and hopefully not over 140 F. The thing is that you never know the true discharge ability until you find out how many cycles its good for at 80% of C. IMO, I wouldn't suffer a LiPo to more than 75% of its C rating even if I paid $200 for a first class 3S 3200 20C pack. Then I might even figure the packs are closer to 3000mAh & 3100mAh. But if money is no object and you don't care if you only get 12 performance cycles than GO for it.
.75 x 20 = 15 x 3.0 = 45A (max cont discharge if I expect to get more then 25 cycles) with reasonable care.
.75 x 25 = 19 x 3.1 = 59A (max cont discharge if I expect to get more then 25 cycles) with reasonable care.
Thanks for the info.
Currently my set up is 40 A draw at 11.1 V with a 3s 2000 25 C so I am discharging at 72 % at WOT
So if I buy the 3S 3200 20C pack I am discharging at 62 % ( better )
The 2 packs are only $12.00 apart ( no big deal ) but the 20C packs weighs 55 grams less.
That is over 5% of my AUW. So I think I will by the 3200 20 C pack
I am a firm believer Less Weight = Better Performance
