RCU Forums - View Single Post - Pull Pull Control Horns?
Old 05-08-2003 | 10:21 PM
Prboz-RCU-delete
Default Pull Pull Control Horns?
Not only should they be even, but they need to be in line with the pivot point on the rudder. You also have to make sure that the servo pivot points are inline with the centre of the servo. This helps stops getting one tight and/or loose Push pull wire.
