RCU Forums - View Single Post - OT-34/76 FO++
Old 06-01-2008 | 03:39 PM
Alan123's Avatar
Alan123
Default OT-34/76 FO++
Hello,
This is a quick report on my OT34/76 project. The OT designation means the flame thrower version and in this case the FT is mounted in place of the hull MG.
Here are the finished pics:
This is how the model was built:
Video and more to follow of actual flamethrowing but this one is not bad we made it last weekend: http://de.youtube.com/watch?v=ejY_1n9pV_s
Sadly I did not take many pics during the actual construction as I was too busy building and then planning the next bit and before you know it it is all done.
The model was made from a combination of the WASAN T34/85 kit and the Trumpeter T34/76 kit, plus a super Alu hull I found in eBay. I drive my models hard in all types of terrain, they must all have metal tracks and must be able to take the punishment. Due to these prerequisites a metal lower hull is a must. Anything else will contort causing the tracks to come off.
The lower hull from eBay had no suspension, just axles bolted into the sides. This I changed by installing a torsion bar system using parts from a Tamiya King Tiger. The T34 did not have a torsion bar system but one must make comprises in modelling. The model is quite heavy and has a nice fluid springy bounce to it as it drives around, thanks to the torsion bars.
The Model is driven by a set of the normal HL metal gearboxes, this gives a good balance of speed and power. These particular gearboxes were taken out of another model and were already over one year old and nicely run in and so are nice and smooth and quiet. All my models have HL metal gearboxes in them and I think they are fantastic. The HL gearboxes drive the metal tracks for the T34 from Asiatam (a sister firm of HL) and come also well recommended and I have not yet had one fail.
The tank is controlled by Tamiya Pershing DMDs and so it has a nice diesel engine sound and all options such as lights, recoil, turret turn and gun elevation etc.
All working mechanical parts are tamiya except for the turret turn which is the original WASAN unit. The Pershing recoil unit is used.
There is a 6 channel 2.4ghz radio control system and the 2 spare channels are also in use. One operates the remotely openable drivers hatch and the other turns the flame thrower on and off.
The remotely controlled hatch is operated by a mini servo. The remotely controlled flamethrower is operated by a larger servo that pulls the trigger on an oven lighter and makes a nice flame. The gas tank is refilled by poking a long needle through the centre of the spare idler wheel mounted on the rear of the hull that then goes inside to the tank. This saves taking the model apart each time. The front of the tank has alu plating to deal with any heat issues that might arise.
Taking the model apart is not done lightly as there as so many pipes and cables to watch out for and plug back in. That is why the battery is permanently mounted in the tank and charged still mounted inside, I take the risk that the whole thing could one day blow up. (though this is highly unlikely, more of an urban myth than reality)
The battery is fixed in the hull and is charged in the model using the Lipo balancer cable that hangs out of the model near the antenna pot. In the same location are the 2 on off switches for charging (hidden under a box). The 2200mha Lipo is small and delivers about 45mins of running time with smoker on and loudspeaker up high. The model is relatively small at this scale and so does not have much room for the electronics, mounting extras like the flame thrower and hatch opener was really pushing it.
Despite the space limitations there is also a smoker to simulate exhaust smoke. Between the 2 gearboxes is a home made smoker unit, it is an alu box with a computer fan on the outside and a model train smoker inside with silicone tubes that take the smoke to the stacks. It works ok but needs constant refilling.
You can see the components in the pictures. The final layout was different than that shown in the photo in that the speaker and DMDs have changed places. Also the magnet idea of holding the top on was replaced with screws.
Other features are that the 2 turret hatches are openable and a figure goes up and down with the gun as it sinks and elevates, naturally opening the hatch as he moves.
The model has a Tamiya Battle Unit and this plugs in at the rear of the turret once the camo net and ventilator dome are removed.
In finishing the model I did:
Texturing of the armour plate with various sized burs with the dremel.
Weld seams with plaster and wood glue mix squeezed on with a syringe.
Metal rod replaces all handles and otherwise fragile parts where possible.
The MG/FT housing was given a cast metal look by texturing a mix of Tamiya Basic Putty and plastic glue with a toothbrush.
Sheet alu mud guards.
Tons of stowage, the Trumpeter kit has lots of bits that can be used.
The model was given an overall spray can coat of olive green to the upper hull, mud colour to the lower hull. Then brown stripes with an airbrush and then weathered with artist oil paint washes and highlighting and chalks. The tracks were sprayed matt black and then mother nature did the rest.
I will add a movie of the tank in action soon. (it is being cut at present)
Hope you like it.
Cheers
Alan.
