RE: Nitro Planes Extra 260 Video
I've put together two NP Pole Cats, three NP Yak 54s, and am currantly putting together a NP 260. The 260 looks to be the best built of the bunch. Everything is glued tight. I will go over all accessable joints with ca anyway. The hardware suprisingly looks useable. Will however use dubro controll on the rudder pull-pull. All looks good except the ailerons have some twist in them towards the tips. Looks like washout. Dont think it is designed to be though. May try to streighten with counterbend and heat on covering. I am going to outfit it identical to my Yak so I can do some comparison flying. The manual I got is for the redbull version. Similar enough to use but I wonder about the cg. Anyone know where the 260 is saposed to ballance?
