RCU Forums - View Single Post - Balancing - Confused
Old 06-01-2008 | 10:14 PM
sean444
Default RE: Balancing - Confused
If you have the plane on the balancer at the recomended CG and the tail is sitting low then it would be tail heavy. Add weight to the nose ore move the battery forward (do this first) to get the plane to sit level.
Good luck
Sean
