RE: "SIKK" Engines
RhesusMinus
You said you tried longer screws with washers. How much longer were the screws? Did they bolt through the water cooling cap to hold the cylinder down from the top? I was wondering because I have done this. Now I'm trying to get some run time on the engine to see how well it holds up. So far, so good. The problem is some of these cylinders break and some don't regardless if they are modified or stock. Others like GlenB are having good luck and not breaking at all. Just doesn't make sense. Looking for the answer!!!!!!!!
Rick
