RCU Forums - View Single Post - Sticky piston ring on Super Tigre
Old 06-02-2008 | 08:20 PM
YUKONFLYR's Avatar
YUKONFLYR
Default RE: Sticky piston ring on Super Tigre
ORIGINAL: kairos
I can’t get the engine to run, one reason is with the lack of compression/ suction, the engine won't draw the fuel through!
Have you tried to blow thru the carb, maybe it is gummed up as well. If so the engine will not run at all. Also the muffler pressure tap may be plugged. If it is plugged it will be a bear to start and keep running.
Try putting a little fuel into the engine thru the carb, then apply glow heat and then electric starter, If there is no glimmer of a start, check the glow plug and make sure it is glowing bright orange. Even with a stuck ring, it should still start and run if it has fuel ect.
Good Luck
Richard
