RCU Forums - View Single Post - The Ultimate EastyStar Brushless Combo Thread
Old 06-03-2008 | 05:36 AM
Andrew86's Avatar
Andrew86
Default RE: The Ultimate EastyStar Brushless Combo Thread
Brushless Motor Type/Name: Himax 2815 2000kv inrunner
ESC Name & Amps: E-watts 25A
Battery: Fightpower EVO25 11.1V 2200mAh
Charger/Brand: Swallow 2 Advance AC/DC charger
Minutes Battery Lasts: Easily up to 30 minutes, maybe more
Prop Type/Size: APC 6x4E
Receiver Name: Spektrum AR6000
Top Wind Speed (MPH) combo can fly in: Have flown in 25knot winds, don't know what gusts were but it handled the wind fine.
Motor Pod/Nacelle - On/Off/Custom: Motor is identical in dimensions to the original speed 400 so i mounted mine where the stock motor would go, very simple.
Using it for: (ex. FPV/Aerial photos/Leisure/Sailing/Speed?): Used it to learn to fly and land well, I haven't crashed since buying this plane over 6 months ago.
Comments about your Brushless EZ w/ combo: Plane will take off from the grass despite the lack of landing gear. Long run times, easy to install, rock solid.
