RCU Forums - View Single Post - 4 cycle experts?
Old 06-03-2008 | 10:16 AM
  #40
Sport_Pilot's Avatar
Sport_Pilot
Default RE: 4 cycle experts?
I respectfuly diagree.... you could not get enough oil to the cam/wrist pins/main/and lastly, rockers.
You would simply run fuel oil mix up to the rockers, or use blow by from the valve stems. This is not a new trick larger engines ( in displacement) than a Chevy small block have used once through or blow by oiling systems. They also had valves and rockers to deal with.
