RE: Landing with the wind
Once you try it, and see how long it takes to either land, or put it down hard, you will probably end up using the little flag on the end of your transmitter (unless you are 2.7 ghz) to tell which way the breeze is blowing, and land into the wind. 3 to 5 miles an hour, you will be able to land, but you will use up about 50% more runway doing it.
