RCU Forums - View Single Post - Unsightly Drop of CA
Old 06-03-2008 | 05:28 PM
opjose's Avatar
opjose
Default RE: Unsightly Drop of CA
ORIGINAL: RappyPilot
I build an ARF and while gluing on the hinges a drop of CA fell on the wing. Wiped it off as soon as I could with a cloth but the are some streaks of dry CA that I can't get off.
Marcel
If the CA is hard, you can put several folds of cloth over it and soak the cloth with acetone.
Doing so prevents the acetone form drying so quickly.
Leave the cloth on the area for about 4-5 minutes and then apply a bit more acetone, and wipe the area.
Repeat until the hardened CA has been removed.
As already posted, use WD40 to remove the leftover white "haze"...
