ORIGINAL: antiquefer
Stan. I put a 4 oz heavy hub on the prop shaft and another 2 oz of led screwed to one of the engine mount rails. The engine is a saito 91, so if your engine is smaller (lighter) you will have to add more. Mabe other piolets will like it more tailheavy. Mine setup like it is lands very easy, which is what I want with this plane. The ballance point has got to be from the top wing.
Thanks for the info. If I may ask, where did you put your battery?, and do you balance the plane inverted or upright? Thanks again, Stan
