RCU Forums - View Single Post - Do I need a reed block
Old 06-04-2008 | 07:57 AM
jack1933
Default RE: Do I need a reed block
Hello You could mount the carb directly to the intake port, however, hot restarts may be a problem as the fuel is boiled off when the engine cools down. the block you are refering to is a spacer, not a reed block. My advice to you is to keep the spacer, as it insulates the 275-320 degree cylinder heat from the carb. Good luck
