RCU Forums - View Single Post - BH T-28 Assembly
Old 06-04-2008 | 08:21 PM
JimO
My Feedback: (7)
Default RE: BH T-28 Assembly
ORIGINAL: Mr. Mugen
So there are 4 servo's in the wing then? 2 ail/2 flaps?
That is correct. That is why they tell you seven servos. Install is easy.
The hardware package is complete and of decent quality. I have decided to use all that is sent with the plane to make it a good review. I plan to do a full report once done, but here are a few more photos. The wing matched up perfectly and the aluminum tube did not need and filing to fit. 12 minute epoxy used to hold it together. BH include a white plastic masking tape to cover the seam. The control horns are unique, the aileron and flaps have holes pre drilled and using a hot pencil soldering iron I melted out the covering and inserted the black plugs and screws. I used blue thread lock to keep both nuts secured. I did not use the pushrod keepers, Z bended the rod instead, lost a plane to a bad keeper.
More tomorrow.
Going together quickly
JimO
