RCU Forums - View Single Post - DA-85 with MTW-90 Canister use a Throttle Curve??
Old 06-05-2008 | 09:57 AM
arobatx
Default RE: DA-85 with MTW-90 Canister use a Throttle Curve??
Note max rpm at full pwer, then, with your throttle stick at half position, engine running, adjust throttle curve mid stick position in tx to a point that reflects approximately 1/2 the max RPM noted while at full throttle....this will get you a fairly linear 'feel' with stick movement. From here you can fine tune it to your flying style.
Chad
