RCU Forums - View Single Post - BH T-28 Assembly
Old 06-05-2008 | 11:35 AM
JimO
My Feedback: (7)
Default RE: BH T-28 Assembly
Working on the landing gear. Jeers, The hole location for the gear in the wing support block is not shown. If you cut the entire length of the grove it would leave a "Scar" before and after the gear is installed. I started in about the middle and moved very slowly toward the center of the wing till I found the hole. Inserted the gear and marked the other end. again use a hot pencil iron to remove the covering. Will upload photos later, got to charge the camera battery.
IMHO you can't go wrong with this ARF, want a warbird for the weekend. Get it on Monday, fly it on Friday.
JimO
