RE: new design: Strega 45
Thank you both. With your help and support the job will be completed. This is the work I like a lot designing airplanes and the parts.
Maybe I can use on the back the dowels and on the front the bolts. These last jobs are difficult because I have never mounted a belly pan. I only have to make a servo tray with steering, rudder and the elevators. I have started glassing the wings to start with the paintjob. I will make a picture of the complete belly pan. It is difficult to mount this belly pan but the problem will be solved.
