ORIGINAL: gcb
You also might want to check that there are no air leaks around the throttle.
George
Also check around the head and plug for leaks. The AP head shims are very poor quality (mine appears to be made from a recycled beer can) - if its leaking badly, you may not be maintaining enough compression at low RPMs to run.
