RE: B&S 40cc, 4-stroke recipe for success
Got the idle down to around 1,000 rpm give or take a little since this Glo-Bee tach isn't the most accurate. Put the spring back in the carb pump but still can't open the throttle past half way. Tomorrow I'll try a smaller prop and get some high rpm tach readings or at least find out what it is turning as far as I can open the throttle.
