EVERYONE TAKE NOTICE!!!!
I contacted Hobbycity with the proper invoice ID to ask for the price of the rear case for my SV 100-cc engine and this was their response.
I will post a add from their web site of the engine also.
SV100-Twin
SV 100cc Twin Gas Engine CDI 7.1kw (ver2)
SV100-Twin 100cc Gas Engine. (Ver2)
Engine type: dual cylinder, 2-stroke, air-cooled
Bore x stroke: 44 x 32.8mm
Piston displacement: 100cc
Max. power: 7.1kW/7,500rpm
Max. torque: 6.8N.m/7,000rpm
Min. idle rotating speed: 1,400rpm
Rotate speed: 1,400rpm-9,000rpm
Compression ratio: 8.4:1
Electronic ignition
Spark plug: JENNFENG
Carburetor: Walbor pump type/diaphragm
Start mode: Electric Start
Dimensions: 275 x 230 x 210mm
N.W/G.W: 3100/3535g
The version 2 engines is a great improvement on the previous model. Stronger crank case, better porting and overall better casting and finish make the version 2 a much stronger and more reliable gas engine.
FYI.
Photographer mounted carburettor backwards in photo. Stocked motors will have carby facing other direction.
3950g 18
$499.99 Buy 1 Buy 2 Buy 3 Buy 4 Buy 5 Buy 6 Buy 7 Buy 8 Buy 9 Buy 10
Hello,
Thank you for your e-mail.
Its $437.95.
Best Regards,
Ricky
Customer Support
Hobbyking.com
We are commited to assisting you as best we can.
Was your request handled professionaly and resolved within a timely manner?
Voice your concerns to our complaints department (
[email protected]) should you feel your issue was not resolved correctly.
*Emails sent to
[email protected] may not be responded to, however they are used for training and service quality purposes.
*Our complaints email address is not a support service.
E-mail message checked by Spyware Doctor (5.5.1.322)
Database version: 5.09990e
http://www.pctools.com/spyware-doctor/
Hello,
I'm sorry, my mistake.
The price that I gave you is for the SV 100cc Twin Gas Engine CDI 7.1kw (ver2) not the rear case.
The price for the rear case is about $10.00 but we don't sell it separately.
Only if the SV 100cc Twin Gas Engine gets broken, then we will give it as replacement.
Best Regards,
Ricky
Customer Support
Hobbyking.com
*Emails sent to
