Which Gear should I use
I stripped a couple gears on my Volcane S30. I counted the teeth on the gears and one was a 17 tooth gear and the other is a 27 tooth gear. My manual lists both of those gears coming in a set, but all I can find to buy is the 19/27 tooth gear set? Can I use a 19t gear in place of the 17t gear, and will it make a big difference? Thanks for the help.
