RE: Project... maybe...
I put a different motor into it and made the nozzle so it would compress the stream a bit more. I will post a video later today showing it at max thrust so you can see and tell me your opinion... the boat's target weight is three-four pounds, electronics are 2 pounds. the hull will be made from balsa and sheeted with thin plywood. Then I plan to coat it with polyurethane or epoxy.
