Big Tire Ofna
Yes, you can fit them (17mm hub btw). The problem is gearing. The ofna trucks use much larger spur gears to compensate for the larger tire diameter. If you are looking to convert, see if the monster pirate center differential (and diff mount) will bolt directly onto your 1/8 scale chassis.
When all is said and done, it may be cheaper for you to find a used monster pirate.
