RE: Need to quiet down my DL 50
Hello.
The standard DL silencer can be easily modified to reduce the noise and with very little cost.
Just get some tube that is a tight slide fit into the existing outlet and blank off one end. Slide it into the outlet as far as it will go (blanked off end first ) then mark and cut it to the same length as the existing one also mark which part of the tube is actually inside of the cannister section.
Drill 4 x 1/4" holes evenly spaced into the new tube at a point that is inside the cannister body. You now have a restrictor that you can "tune" by adding more holes of varying sizes to acheive the desired effect. The 4 starting holes will be enough to get the engine to run. A little power loss will be inevitable.
The new restrictor is held in place by drilling a couple of holes thu' both tubes and secured with self tapping screws.
When you are happy with the "tuning" the fix can made permanent by smearing a little exhaust compound around the the restrictor tube as you finally fit it.
Good luck.
Mike.
