The MTR-3 has a center differential where the MTR-2S has a 2 speed transmission. The center diff will make the truck turn better by allowing the front wheels and the rear wheels to turn at different speeds. Unless you plan on really racing you probably wont notice a difference between the two as far as the diff goes. The MTR-3 also has a slipper clutch which takes some strain off the transmission if you do a lot of jumping. With the 2 speed transmission there is no slipper clutch so its easier to strip the spur gears if you land hard while still on the throttle.
Hope this helps.
Also, make sure you do an ebay search before you buy either truck. You can find them on ebay from a lot of different stores for decent prices.
ORIGINAL: decompetencia
Hi
I am going to buy a himoto car, but i wounder wich one is better,
the MEGAP MTR-3 or the MEGAP MTR-2S, wich one os those did you recommend me?
what are the difference in the moment of running
thanks
