ORIGINAL: gaRCfield
So these rods are already attached and heat-shrunk to the metal rods. The wood ends are tapered and wrapped with what looks like electrical tape. The wood part is 16" long.
Again I'd like to ask why I shouldn't replace them with the metal rods from the Nexstar. Sorry if this was mentioned, somehow I'm just a little confused. They do seem to be a HAIR lighter, but nothing to write home (or to you guys) about. They are FAR from being straight (wood is straight, but metal part goes in at an angle at both ends, not part of design). And I don't see how to support them (no given hardware).
For the metal rods from the Nexstar, they are in good shape, plenty long enough, and the tubes are long enough to extend from the exit hole in the fuse all the way to the servos if I wanted them to.
Thanks for the advice...
The metal push rods in your Nexstar require a plastic guide tube that needs to be supported at both ends at minimum. Supporting it in between is helpful too. This will likely require some modification to the fuselage, adding balsa braces, etc. (all very doable of course) If you are ready to take on that sort of modification, fine. It is your plane after all. I figure that there is no reason to fix what isn't broken. There is no need to do the additional work. The wooden push rods will get the job done fine. If anything, I'd just make new wooden dowel push rods if the ones supplied with the plane were questionable. I subscribe to the keep it simple philosophy.
My World Models Rambler 45 uses a wooden dowel for the elevator. It has two wires that "Y" at the end to control each half separately. I was leery of this at first but I decided to run it. The plane is extremely fast and very aerobatic. There has never been an issue with fluttering, binding, flex or anything else. It works great. My Phoenix Sukhoi used dowels for both elevator and rudder. It was a VERY aerobatic plane and there was never an issue other than me dumb thumbing it into the ground. Your Dolphin isn't as advanced as either of those planes. It will be fine.
